lastsplash
Shoe and Shoelace; one is meaningless without the other.
Would like to hear your opinions on the exaggerated cables meant to mimic a stock look but with some panache. And your thoughts on anything else for that matter. The power supply for the MORA is still in the mail and I still need to flush the rad but otherwise it's ready for the leak test.
The PSU and pump will both work hard but should be fine. (famous last words) The goal here is to be as quiet as possible without sacrificing too much performance.
Shoe:
MO-RA3
Heatkiller 150 Res
D5 Next pump/controller
EK fittings and tubing.
Alphacool QDC
Noctua 200mm x 4
70W molex power brick
Shoelace:
XTIA Proto-L
Asus X670e-i
AMD 7950X
Zotac Trinity 3090
4TB WD SN850X M.2
1TB 980 Pro M.2
64GB Corsair DDR5 5200
EK Supremacy CPU Block
EK QV GPU Block
Alphacool QDC
700W Seasonic Fanless PSU
Shoelace is fanless except for two small fans on the motherboard, unfortunately. Hopefully they won't be too loud but small fans be loud so we'll see where the temperatures are with the open air case. Maybe they can be disabled if the VRM and chipset don't get too hot. That's really wishful thinking.
I plan to swap the line from the rad to the res with hard metal tubing in the near future.
I can't decide between distilled water with biocide or a clear coolant. Any recommendations?
Shoe:
MO-RA3
Heatkiller 150 Res
Alphacool QDC
Noctua 200mm x 4
Shoelace:
XTIA Proto-L
Asus X670e-i
AMD 7950X
Zotac Trinity 3090
4TB WD SN850X M.2
1TB 980 Pro M.2
EK QV GPU Block
Alphacool QDC
