should i be concerned?
Shadowarez
Folding Team
Arctic Canada
i have those asus sage boards in for repair in states i bought entire socket 2066 replacements lol hoping they can be saved.
Soultribunal
Mississauga
I've done it a few times myself when I started using IC Diamond. Warm is best, or if there is room I would put a plastic Spudger (like you use for Laptops) inbetween.
-ST
gingerbee
Orillia, Ontario
I think anyone who has used AMD chips has done this, funning thing is I don't remember doing it on old intel when they had pins, I wonder if it is more common now with the larger IHS the chips have.
Ya always got to remember to heat the CPU up a little bit and twist off the heatsinks to not bring the CPU with it lol
bassnut
A tip for the future before removing a cooler or water block run prime or something similar for a couple min this will soften the pate and twist to remove as mentioned.
Shadowarez
Folding Team
Arctic Canada
Yeah was thinking doing a simple stress test for a few mins would prob work instead of trying from a cold start. Computer sits off sometimes 24-48 hrs before I can make it back to using it I think when the new 420 arctic arrives I'll switch it up put the 8 GT fans infront and the 6 140mm fans uptop.
As you can see it's a lil too tight for my liking plus I can finally get to sleeving the GT fans.
Izerous
Folding Team
Edmonton
Others have said heat and twist which are also good suggestions however there is one that I have not seen yet. Crappy thermal pastes... there are a bunch of thermal pastes out there which are a glorified glue more than a thermal paste not being careful about how much you apply can also change the risk of this happening.
Edit: if you brought that down one slot there would be a touch more slack int he lines
Shadowarez
Folding Team
Arctic Canada
yeah with this stuff TG Extreme i though a small amount was enough but it certainly spreads out i have to use even smaller amount then say Noctua NH, Arctic MX,
Cannon Fodder
Lower Mainland, BC
I'd argue that bent socket pins are harder to repair than bent processor pins.
No argument from me on that one, because I know that to be true, from 1st hand experience..... unfortunately.....
I had that happen 2 or 3 times, back when I was using P4 on Socket 478, and a few family members were too..... it's definitely disconcerting, but once you realize what's happened, and see that all the pins are still intact, it's not that big a deal.
gingerbee
Orillia, Ontario
Ya I kinda figured but I just think its odd more people don't remember those days or are some of us just getting old lol
socket pins are harder but it really something I would like to avoid pretty much all the time 😜🤦‍♂️
