Should I use HeatKiller backplate for LGA2011
geoc
I am setting up my loop for my LGA2011 build, and I see that there is already a pretty thick blackplate.
Since I am using HeatKiller 3.0, it comes with a backplate as well, should I use it? It seems like it'd be a pretty tight fit since the LOTES backplate is pretty thick and I just stack the new backplate on top of the LOTEs one, I need to screw in pretty deep for the screws to reach the HeatKiller backplate.
Any suggestions on what I should do?
Thanks!
SugarJ
Folding Team
Langley, BC
I just used the stock backplate with my HK 3.0 on a Rampage IV Extreme.
