dustin1706
- Joined
- May 31, 2010
- Messages
- 718
Going to do a new build, not sure what platform. Debating a new 7700k vs a 6850k / 6900k. Maybe a Caselabs SMA8?, water cooled (4x120 or 4x140 each for CPU and GPU depending on case, Push fans) and maybe I'll try some hard lines this time around. I've got this thing against loud PCs, I want it to be sitting beside my desk and not be able to hear it. No fan noise, no coil whine. I'll accept HDD noise when transferring files and loading games begrudgingly. So, I've got a huge pile of fans that either came with cases, or I purchased and hated the acoustic characteristics of. The fans I currently use are some ~2012 Noctuas PWM'd to ~700 RPM and Gentle Typhoon AP-12s (800 RPM, but discontinued).
This said, I've got a few fans I'm considering and wondering if anyone has tried these or has any thoughts. The dB specs, generally aren't all that accurate as certain frequencies seem to be more irritating than others and some fans are prone to clicking noises when PWM'd low. I'm hoping someone has tried these fans and can provide a firsthand recommendation.
Probably one of these two:
Noctua NF-S12A PWM - Downside is that they have to be painted cuz they ugly and buy the coloured corner dampeners. Upside is that they are quiet and reliable.
BE Quiet Silent wings 3 - Seem ok , odd opening shape. Didn't care for the original silent wings.
Also considered:
Noctua NF-A14 PWM Industrial - They are black and you can just get the colored corners for them . Downside is that they are over $40 CAD, 2000 RPM max and still need to buy coloured dampeners.
Corsair SP120 PWM Quiet Edition - Look good, coloured rings can be easily painted, but even their own CFM and dB specs don't come close to the Noctuas or BE Quiet so I think not.
Of course, Thick, low TPI rads to go with the low RPM fans.
Noctua's don't look awful when painted, but I'd probably go for a more matte black frame if I go with them.
Also considered:
