Completed Silent Watcher
akira749
Donnacona, QC
Hi everyone! It's been a while since I a build!!! Things have been crazy for the last months with my daily work and I
haven't had the time to work on new builds since the end of summer.
I'm finally starting my build with the Asus Rampage V Edition 10 and a pair of 1070 Strix...all this inside a beautiful be
quiet! Dark Base Pro 900 case.
I will do a dual loop for the look of it and because I have the real estate to do it inside the case.
The color scheme is very neutral and monochromatic with the beautiful Carbon sleeving of CableMod. The coolant for both
loops will be clear with 2 different shade of UV blue (one in each loop).
So with this I will try to play with both RGB and UV together. If it doesn't look good, I will ditch the UV.
As always, I hope you will enjoy this build!
Build setup/parts listing :
Case
  • be quiet! Dark Base Pro 900 Black
Components
  • Asus Rampage V Edition X99 Motherboard
  • Intel I7-6800K CPU
  • G.SKILL TridentZ 32GB (8 x 4GB) DDR4-3200 RAM
  • Corsair AX860i 860W 80PLUS Platinum PSU
  • Asus GTX 1070 STRIX-GTX1070-O8G-GAMING 8GB GPU's (2x)
  • An old (but sturdy) OCZ Agility3 120GB SSD
Cooling
  • be quiet! SilentWings 3 - 140mm Fans (3x) (the ones included with the case)
  • EK-Vardar F4-120ER (2200rpm) - 120mm Fans (3x)
  • EK-CoolStream CE 280 Radiator
  • EK-CoolStream XE 360 Radiator
  • EK-XRES 100 DDC - Acetal (2x)
  • EK-RES X3 - TUBE 250 (204mm) (2x)
  • EK-DDC Heatsink Housing - Black (2x)
  • EK-RES X3 - Multiport TOP (with 40mm Internal Tube) (2x)
  • Swiftech MCP35X DDC PWM Pump (2x)
  • EK-HDC Fitting 12mm G1/4 - Black (16x)
  • EK-AF Angled 90° G1/4 Black
  • EK-AF Angled 45° G1/4 Black
  • EK Extenders, Plugs and T-Splitters in Black
  • Darkside Ball Shutoff Mini-Valve - Black (2x)
  • EK-HD Tube 10/12mm
  • EK-FB ASUS R5-E10 Monoblock RGB Edition
  • EK-FC1080 GTX Strix - Acetal+Nickel GPU Waterblock (2x)
  • EK-FC1080 GTX Strix Backplate - Nickel (2x)
  • EK-Ekoolant EVO CLEAR Coolant
  • Mayhems Non Stain Dye - Clear /UV Sky Blue
  • Mayhems Non Stain Dye - Clear /UV Ice Blue
Sleeving, lighting and misc.
  • CableMod C-Series AXi, HXi & RM ModMesh Cable Kit - CARBON
  • CableMod ModMesh SATA 3 Cable (12") - CARBON
  • CableMod WideBeam Magnetic RGB LED Strip - 60cm (2x)
  • DarkSide CONNECT Dimmable Rigid LED Strip - UV Rev4 - 30cm (2x)
  • Aquacomputer Aquaero 6 XT Fan Controller
techsavyy
Active member
Lindsay,ON
Looking forward to seeing how this turns out! I just purchased a Dark Base Pro 900 as well, love the case.
akira749
Donnacona, QC
Sorry guys, I was sick (even still a little) and it drained all my energy. I will resume the build since i'm better now. Cheers!!!
Lysrin
Nova Scotia
Don't worry about it akira749. We'll be patiently waiting. Your builds are always worth the wait! :)
akira749
Donnacona, QC
Sorry guys it's been a long time since I posted!
Some delays with work but also with the build. I had some ideas for the reservoirs placement/setup....I tried many and I even switched the case from standard to inverted to standard to inverted and back to standard lolllllll
Nothing was going like I wanted. I tried different lengths of reservoir tubes all together and even than....nothing was going the way I wanted.
This week I had another idea and it might be the one I will use. I will try it today after I post this reply.
While some things weren't going the way I wanted, I had the time to install the blocks on the board and on the GPU's and installed them in the case.
Here's some pictures to show where it is now. Like I said, today i'm working on the pump/res placement and from there I should be able to begin the loop.
Monoblock installation!
GPU blocks installation!!
Installed in the case!!!
Take care and see you really soon!!
JD
Toronto, ON
Any plans to cut the heatpipe so you can keep using the I/O shroud? I do like the look of that monoblock though...I was close to buying it...
akira749
Donnacona, QC
I tried to heat it to see if I could keep the IO shield heatsink part but without success. Since I didn't wanted to cut the pipe, I decided to give it a shot with it and overall I like it even without it.
takitoes
Active member
Place holder so I can find this later, looks like you have the start of something awesome :D
