Slow Post and Slow Windows Loading
moocow
Vancouver, BC
I'm using a Z68X-UD4-B3 board with F10 BIOS and I'm seeing the following problem:
1. Slow AHCI BIOS boot up, takes 2 minutes to detect drives.
2. Slow Windows loading, takes 2 to 5 minutes to load.
3. USB 3 ports are very slow to dead flash sticks.
I'm using a M500 SSD as Windows drive but using a regular HDD to store User data (download and stuff). Could it be one of the SATA drives acting up?
KaptCrunch
Ontario
sounds may be bad memory, drive, optical and usb device
remove all devices to see if clears then add 1 by 1 to find bad item
Etron EJ168 USB 3.0 Driver 1.0.0.118 date 2013/11/26
also check usb header connections on MB are correct
KaptCrunch
Ontario
for your SSD what firmware your at ? current is MU05 Release Date: 03/25/2014
Version MU05 includes the following changes:
  • Improved Drive latency performance in applications with SMART polling
  • Improved Compatibility with 3rd party encryption management software
  • Corrected Reporting of SMART attribute 196 and 183
  • Increased thermal throttling response on 960GB Capacity for greater reliability
  • Corrected Upgrade issues experienced on MU03 by some customers
  • Numerous Bug fixes and stability improvements
Additional details can be found in the firmware guide pdf
ShinraCorp
St-Augustin-de-Desmaures
Wouldn't it just be the Mobo itself the problem? I mean it's all related to the Mobo.... It can't be ALL of them the problem.
Sagath
Folding Team
Edmonton, AB
When did the problem start occurring? If this is very sudden, did you update the BIOS recently?
If you didnt upgrade the bios your board has 2 SATA6 chipset ports, and 2 Marvell. Try switching the boot drive to the other SATA6 ports.
The USB3 problem could be related, but probably isnt. That board uses a separate chip for the USB3, too. I would ignore it for now until you isolate the SATA issues, and then worry about USB3.
moocow
Vancouver, BC
The problem started about 1 week ago. I had the board for about a few months after buying it off another member here. I'll start disconnect drives one at a time to see what's wrong. Today, I notice the LEC light on the mouse would go out during Windows loading. When the light comes back on, then I see the log in screen.
BIOS was just updated from F9 to F10 last night but no effect.
