Slow windows startup need help?
kr7777
India
I had been using windows 7 64-bit for about 6 months (samsung hdd 500 gb),howmuch rpm dont know.my pc starts in 50 sec.
Generic User #2
...that doesn't sound slow at all for a harddrive.
are you saying its slower than it used to be?
KaptCrunch
Ontario
check all your HARDWARE drivers are up to date like sound, video, chipset, lan and bios firmware NOTE update in dos only when flash bios, make sure you have correct file for your motherboard version if applicailple
if a laptop go to manufactures site and get updates
AkG
Defrag the HDD. Make sure the OS is on the 'fast' part of the HDD.
See what apps are loading on startup. Turn off the ones you dont NEED to start on bootup.
Run Malwarebytes anda GOOD A/V to make sure you dont have nasties on the rig.
Update all the drivers and firmware to latest versions.
IF its still slow after doing all four. Then you have a hardware problem. Most likely its just a SOFTWARE problem.
Shadowmeph
are you talking about slow as in getting to the desktop or actually loading the desktop ?
moocow
Vancouver, BC
Or are you talking about how it sits at black screen after you log in and wait like 1 minute before it loads desktop. I experience that as soon as I install all my Win 7 updates.
kr7777
India
you are also right moocow it does as you said . what is the solution of that problem?
kr7777
India
actually i noticed all of the three posts (akg , shadowmeph , moocow) are correct about my problem.
slow as in getting to the desktop & actually loading the desktop also.
