I purchased a few different NVMe enclosure's a few months ago and have been trying them out and I thought I would do a small review incase anyone is looking for a decent ssd enclosure.
The Unionsine and HIKEMI are the same enclosure's they just have different styling,the only thing different between the two enclosure's circuit boards is into upper righthand corner of the enclosure by the usb c connector and I think the HIKSEMI has a bigger capacitor but I'm not sure what the part is for sure,these 2 enclosure's also come with an extra screw that holds the ssd down at the back end of the enclosure.
All 3 enclosure's come with the same accessories such as a wrist style strap 2 usb cables an A to C and an C to C cable,all 3 enclosure's also come with thermal pads as well ,the Jeyi comes with the red thermal pads and the Unionsine and HIKSEMI come with grey thermal pads shown in the picture's with the enclosure's.
The Unionsine and HIKSEMI use a Realtek RTL9210-B usb controller and are 10Gbps and they also support NVMe and Sata ssd's,with real world testing using a Sabrent Rocket 4.0 1TB ssd transferring large files that were 20Gb I got rock solid 712mb's while being plugged into my usb 3.1 gen 2 port on the backside of my mobo.
The Jeyi enclosure came with 2 screws that hold the back of the enclosure on a silver and a black screw and also came with a screw driver wrist strap and 2 usb cable's as well for A to C and C to C connections.
The Jeyi use's a Micron JMS 583 usb controller and when I tested the Jeyi enclosure with the same Sabrent ssd I got the same result's 712mb's speeds.
What I found with the Jeyi enclosure it is made of thicker aluminum for sure then the HIKSEMI and Unionsine enclosure's and you can feel the weight difference in your hand,I also found that because the HIKSEMI and Unionsine enclosure's use slide on backs that it didn't feel like the thermal pad made great contact with the back panel of the of the enclosure.
I found that with the Jeyi enclosure because that set's in and there is a small tab on the end of the back plate that goes into the enclosure where usb connector is located that the thermal pads made better contact.
I wouldn't say that it's a deal breaker with the Unionsine of the HIKSEMI that the thermal pads don't touch the case that well because I found with a good quality ssd like Crucial and Sabrent they didn't get very warm at all if the thermal pads were used or not.
With the Jeyi having more aluminum I wouldn't say it's a concern that the HIKSEMI and Unionsine are going to be weak or flimsy all 3 enclosure's are very solid and well built and machined nicely.
All 3 of these enclosures are made by the Unionsine company and they also make Orico and Yottamaster enclosure's as well as other brands from what I understand.
I'm posting links to each enclosure and I want to be clear that I'm just an end user of these enclosure's and I in no way have anything to do with aliexpress or selling them.
Depending on what the Canadian dollar is doing you can find these enclosure's around 16 and 19 bucks,I was able to get all of mine at 16.76 Cad with free shipping and all took at about 10 to 14 days to arrive.
https://www.aliexpress.com/item/100....order_list.order_list_main.29.5aad1802PTWD26
https://www.aliexpress.com/item/100...order_list.order_list_main.115.5aad1802PTWD26
https://www.aliexpress.com/item/100....order_list.order_list_main.11.5aad1802PTWD26
