*sniff* - a sad day.
b1lk1
Lindsay, Ontario
You're using the wrong shops if they cannot diagnose this.
Also, if it shudders some of the time but not all of the time then it is the transmission. Not sure why a transmission costs $5K, should cost about $1K to rebuild it and the same or less to install it.
Wicked15
Nova Scotia
I agree with B1,
Is there any correlation with load? uphill, downhill, while turning? Did your mechanic put it on the hoist by a foot or 2 and let it idle in 1st and 2nd gear and maybe turn at a slow speed to see if the results still happen when no load is on the tranny. Does it only shudder at the start of a gear until you get to a "certain" speed or revs? If it's only during acceleration than I would say that rules out a driveshaft or u-joints as Any time I've had a DS or u-joint go bad they would act up at the start of acceleration(or not until a certain speed) until you get up to speed and spin themselves out or and as you let of the gas, they would act up again at that same speed during deceleration.
b1lk1
Lindsay, Ontario
Driveshaft problems are a constant, they do not manifest in the way he described. Driveshaft problems get worse with speed. THere is almost always a noise involved with driveshaft issues.
Knowing it is a Ford, I would really stare hard at the transmission. In fact, anything older than 99, I would REALLY look hard at the transmission.
I stand by that you have the wrong people looking at it and I could build a full racing transmission that could handle 1000HP for less than $5k....
KaptCrunch
Ontario
wanted to know when it came and yes Driveshaft do get worse with speed when are out of line
sounds if one shift accumulator is leaking in transmission will cause a shudder every time it shifts
yes time to find another shop that knows how fix vehicle's not their bank account
BrainEater
Calgary
Yea , the transmission rebuild was estimated at 3500$.
There's a bunch of unrelated stuff that needs fixing , for about 2 grand.
Not too worried about it.
I'm driving a shiny new 2016 f150 xlt......company vehicle,insurance and gas paid.
:thumb:
BrainEater
Calgary
Roger that !
They offered , I said Yes, Please !
:clap:
I've got some time now. Trucky is registered and insured till next summer, and it has a place to stay.
Mebbie it's not quite dead !!
I think I'm going to learn some auto mechanics over the next 6 months.
hehe
:ph34r:
