(SOLVED) 1080 gtx poor performance,stuttering
Groove
Ottawa(ish)
Drivers | GeForce
That is where you want to get your drivers. The ones you can get from the card manufacturers are outdated most of the time.
Uninstall whatever you installed from Zotac, you can use Display Driver Uninstaller as well and then proceed with the a clean install of the NVidia ones.
Jim
an hour out of Calgary
I have this installed Version 378.66 - WHQL ,I ran an older version of DDU in safe mode for both nvidia and amd ,will try again with the latest DDU
Jim
It appears video drivers were never the issue,games play fine in single player mode,in multiply BF1 I noticed yellow and red symbols for packet loss ,then I noticed the HDD light was on constantly (confirmed in task manager HDD @ 100%) ,coincidence with video card installation ?
MARSTG
Montreal
HDD 100% means probably is busy with the swap file? You only have 8GB RAM and probably not enough. Somebody was having the same issue with the Division, these modern games probably require 16GB for optimal performance. No SSD mentioned in your configuration, you have mechanical HDD?
KaptCrunch
Ontario
what's running in the back ground ?
are the chipset drivers up to date last was
MEI: V11.0.5.1189
I see Z97-A BIOS 2801 was last
Asmedia_USB3_V1.16.35.1
intel
bad data cable?
Jim
Turns out I have 21 Trojan malware infections ,suspect thats a factor,new ssd coming this week,vidoe drivers are fine cause single player BF1 runs trouble free
Jim
MEI: V11.0.5.1189
intel
bad data cable?
Lots of malware doing a clean install once a new ssd arrives,chip drives are current,cable's great point
