[SOLVED] PC Freezing During OS Install
x15Artx
The SSD must be the sole drive connected (Unplug All PC hard drives before installing OS on the SSD)
katmando1036
Member
I'm currently actually trying to install to the HDD with the SSD disconnected, as I have already tried to do it as you mentioned.
katmando1036
Member
what about a win 7 usb disk? I hope you got the right bios, as the Phenom X4 905e is supported only by the last revision, 3303. When it boots, you should be able to see the bios revision, unless it boots with that Asus wallpaper.
Windows 7 USB did not work.
Downloading Ubuntu
MARSTG
Montreal
just in case, consider a Bios reset and load optimized defaults. that might help.
