Some folders wth?
LionRed
Dargaville, New Zealand
This is something I noticed in the past (but now it is getting on my nerves).
I have all permissions set properly, shares properly etc. Everything I can think of. HomeGroup Sharing blah blah blah.
I have a pictures folder with folders in it (approx 600 folders in the main picture folder on a backup drive). I can access 99% of the folders fine (they've gotten shared perfectly fine when adding them to HomeGroup Shared). Yet the odd one keeps giving me Windows cannot access\\gamingrigii\d\Backups\All Pictures\House Pictures. Because Windows 7 isn't adding it to the HomeGroup for sharing (when I added the main All Pictures to the HomeGroup Share).
It just doesn't make sense. I can't figure out why the other 590 folders get added fine, yet there are a few that won't get added to the HomeGroup sharing. In order to get into these odd folders. I have to first come across the problem folder and then manually add it to the homegroup share.
Anyone else had this issue and or know about this problem? And is there a easy fix?
dustin1706
I've had the same problem when sharing with homegroup. Not sure if it's an option for you or not, but I now always share with "everyone".
Shadowmeph
I know what you mean the same thing happens to me I don't even bother with home group any more it is just to screwy for me, I used to never have a problem with it but now it just doesn't work.
I ended up just right clicking some folder and doing the allow all and just connecting to it via network, I just make sure that the folders I do this to have nothing I don't want messed with inside. I know that this is totally the wrong thing to do but it is the only way for me to share anything across my networks laptops and PCs
LionRed
OK thanks guys. I reckon this is what I will have to do.
I hope this doesn't get worse (folder sharing issue's), forcing me to upgrade to Windows 8 - Hey wait a second!:ph34r:/s
sswilson
Moncton NB
Does anybody out there have suggestions for an open source win7 compatible internal network sharing app/program? I've had issues as well and the only solution I've found is to either share with "everybody", or create a new folder in homegroup for sharing purposes and transfer the information over.
The Quicken
BC CANADA
If you want to share with a specific client, create a User Profile for that client on the PC that is 'sharing' the folders.
Hope this helps:thumb:
