SSD and internet connection.
Goon3d
Active member
Any of you have experienced losing internet connection caused by an SSD or Shaw SMC wireless modem are just straight garbage?
Goon3d
Active member
Do you have another computer to test your SSD theory? Sounds like SMC is just crap if Google prove to be correct.
NCIX FORUMS - shaw and its wireless modem
I don't, I know for a fact that I lose internet connection atleast twice a day, but that is when I still have a mechanical HDD, when that happens I just reconnect to my neighbors modem. Now, I can barely stay online on both network, and the connection are very poor.
JMCD
London
The SMC has an ok modem in it, but the built in router is utter crap. If you are using the router functions and do not have the device in bridge mode, there is your problem.
supaflyx3
Langley, BC
+1 my internet was dropping all the time on my smc modem until i put it in bridge mode and bought a router.
Goon3d
Active member
Thanks for all the reply.
What exactly is bridge mode? Do I still need to buy a wireless router or can I still connect without one?
supaflyx3
Langley, BC
Bridge mode is where your modem is acting just as a modem, the routing part of it is disabled. And yes you'd need to buy a router, and no you can not use it without one in bridge mode.
Scurvy42
Member
I was wondering about Bridge Mode myself. Are there any downsides, other than the phone-hold time w/ Shaw support?
Goon3d
Active member
I will be getting a new Cisco modem to replace my old SMC for free, I wonder if the Cisco modem wireless feature is better than SMC?
