stable driver version for my gtx 260
Bismac
Member
gtx 260 users pls tell me what driver version is stable for my gtx 260 i mainly play warcraft 3 (DOTA) and i also have some new games which runs fine just warcraft 3 is freezing on me..
pls help:sad:
im using 190.62!!!
martin_metal_88
Quebec City
Welcome to HWC!!
Well almost all version are stable. I don't think that your driver have a problem or maybe they are not well installed. It's more looking like a card problem or a game problem. Try to run 3Dmark and stress test on the card to see what it does. You can also try the least version but as I state, I don't think they are in trouble.
Ask for more
rjbarker
Courtenay, B.C
Thier have been a numkber of reported issues with 190.xx Drivers (although it is mostly related to Multi GPU's)...many are still running either 182.xx or 186.xx Drivers.
Not sure how the newest WHQL Driver is.
YukonTrooper
I'm still using 178.xx's. I'm playing Oblivon, though, and everything post 178.xx is slower for it.
headsh0t
Winnipeg, MB
Definately a game install problem (or so it seems). If other games are running fine then it's probably just WC3. Try reinstalling and see if that works. I remember seeing something like this on the NCIX forums where it was ONLY the Red Alert 3 game that was crashing for the guy and everyone automatically was suggesting it was a hardware error/failure. So try reinstalling and then if it still doesnt work then ya, it may be driver related. Did you just recently upgrade to those drivers, and was WC3 working fine prior to that?
Bismac
Member
thanks guys problem solved rolled back to driver 182.50 and i also did some reinstalling.
