Steps on gettin Fahmon setup on Vista
Dashock
Toronto
Hey guys i just started folding with Vista if someone would be as kind as to tell me/us the steps on how to configure Fahmon on vista that would be awesome cheers.
encorp
I'm new around this part of HWC haha, please explain this thread! LOL
Apollo4g
Montreal
I have the new 2.3.2b FahMon, and i cant seem to get it to work either. Im running XP 32.
Help anyone?
LCB001
Aylmer QC.
Help anyone?
I don't use Fahmon, but it should be the same.
From 3.0 Charlie in another thread...
Install GPU2 - make sure you know the path to the Work folder.
D/L Fahmon
Install
Run
Right click the window, clock Add new client.
Add a name for the client
Browse to the Top folder where the Work folder is situated - not the actual Work folder.
It may take a few percentages until Fahmon recongnizes the Client.
Dwayne
Courtenay, BC
there are a couple of programs that let you see the points per day (ppd) you are attaining. fahspy and fahmon. You have to find the working folder though as it is not in the program files directory. In vista it is where I indicated, XP should be in the c:\documents and settings\yournamehere - after that you would hunt it down as I don't have an XP machine to search it out.
Apollo4g
Montreal
D/L Fahmon
Install
Run
Thanks! hmmm i have no idea where my work folder is situated....any address? OS is XP32 pro
Thanks!
Just read that, but still cant seem to find it :sad:
sswilson
Moncton NB
If you look at FAH in your start menu there will be a "data files - expert only" file. Copy the location of that file and you've got the folder you need.
