Steps on gettin Fahmon setup on Vista
Apollo4g
Montreal
If you look at FAH in your start menu there will be a "data files - expert only" file. Copy the location of that file and you've got the folder you need.
Thanks i found it.
For me it was:
C:\Documents and Settings\Administrator\Application Data\[email protected]\work
For all that want the answer :)
SO with this program, i can monitor different PCs/laptops all at once?
Supergrover
Okanagan Falls, British Columbia
Thanks i found it.
For me it was:
Never tried but a hell of a idea, as long as the permisions are set up right in your network and you might have to share the folder.
Apollo4g
Montreal
hmmmm, ill do the testing then :)
It would be nice to have a program summarize your progress on all your folding pcs no matter where they are in the world, may be thought your blackberry as well :biggrin::thumb:
Dashock
Toronto
Yep as Apollo said its exactly like that in xp as long as you have all the hidden folders available to you it was a little different on vista thats why i needed some help and Dwayne had it on the mark. Im finally back up and running again went out for dinner to come home to see my computer powered down i was mad i turned it on was on hibernation i think vista had it turned down in the power settings home it does not do that again.
3.0charlie
Bedford QC
Thanks i found it.
For me it was:
Yes, you can over a network. That's what I do at home. And as Super' mentionned, you have to share that folder in question.
