strange eyefinity issue?
BobbyLou
Calgary
Hello I noticed that 1 of my 3 identical monitors was darker then the other, this only occurs when the display port is used to power the monitor. If I switch it between the 3 monitors whatever one has that particular connector plugged in looks darker then compared to the DVI variants. Being powered off a single card. I checked all the setting in CCC and there identical on all three monitors. Any ideas???:shok::blarg:
hedgehog88
Active member
I dont personally have an eye infinity setup but ill give you some options.
Did this happened recently? Have you tried using another DVI connector?
Behemoth-
Couldn't the DP --> dvi adapter be defective? I believe it ain't the DVI cable since you probably did use a different one for each monitor... Couldn't it be the card's DP port ? Yet I'dd suspect more the adapter..
BobbyLou
Calgary
update -
Just tryed the 10.7a beta drivers and it seems to have fixed the issue...
strange
