Strange issue with power off after OC.
Ruhagan
New member
Hey all.
So I overclocked my PC, it's stable while running for a long time or stress test, but one weird thing happens every time I turn it on for the first time: it reboots few minutes in operation. No blue screens, errors or whatever, just shuts off, boots into Bios, gives choice to reset bios settings to last known good config or get into bios - I get into bios, save and exit (leaving same settings), and it boots fine then and I can run it how much I want with no problems whatsoever... Also PC doesn't go into Sleep mode, it just kinda hangs in-between with fans running and lights glowing.
I hadn't had it in the begining, and since I was tweaking my OC for quite some time to get it to a stable state, I don't remember when exactly this problem started, but maybe someone experienced similar thing and has the answer.
OS: Windows 10
Mainboard: Gigabyte z97MX Gaming 5
CPU: I5-4670k OC'd to 4.5 GHz (Uncore 3.8)
GPU: KFA2 GTX 780ti
RAM: HyperX 16Gb OC'd to 2400 MHz @ 1.65V
KaptCrunch
Ontario
what is your PSU
seems your OC setting can't handle the set-up with PSU may be weak
hence works fine @ stock settings
Ruhagan
New member
I wrote that it works fine at overclock settings after that "mandatory" first "auto" reboot. That's the point, that it turns off once, few minutes after first log on. After that it works fine on same overclock settings.
PSU: Seasonic X-series 750W, 2 years old.
Ruhagan
New member
Overclocking through UEFI (i.e. Bios).
CPU is fixed on 1.26V, lowest stable it seems, below that CPU starts freezing.
