I'm having a strange problem with my Intel i226v Lan controller turning off if I leave my PC running or if I put it to sleep sometimes it comes back on with the PC and sometimes it doesn't.
I haven't had this problem before,I had the problem years ago with Windows 7 with some Lan drivers where the PC would wake up 3 to 1 seconds putting it to sleep if you didn't have the allow this device to wake the computer checked off.
Do you guys think I should try unchecking allow computer to turn off this device to save power,I don't recall having to do that but it's strange.
I also had an install of Windows 11 installed and had to reinstall because a program I had wasn't working right and the only way to fix it was a fresh install of Windows 11,it wasn't acting this way until I did the second intall,I installed all the same drives and used the same Windows USB stick.
When I try to reinstall it won't even show the install,however if I uninstall the driver from device manager then double click on it it loads the driver in but I get no user interface it just show the i226v in the device manager again.
I have a Marvell controller and I could try that one,I hope the Intel one isn't failing and it's just a glitch or something with the driver because this is on my new ASUS X870E ProArt mobo.
