thorn
This isn't a critical issue but was wondering if anyone else has experienced this and found a solution.
The issue is the 'layout' of the steam store within the steam client and some other pages. To better explain here are two pictures:
This is what it should look like (from the steampowered website):
And what it looks like within the client:
As you can see instead of the thumbnails lining up horizontally they are vertical. The text below is also messed up. For example where system requirements is split in 2 columns (one for min or for required) in my client they just follow after each other.
I tried searching the steam forums but wasn't really sure how to word the search, so I didn't come up with anything. Looked through their support as well, and tried out deleting winui.gcf but alas it did nothing.
for the life of me I can't figure out why this is happening, it just started one day. And a couple days ago it worked properly again, but then back to this improperly aligned layout.
Any ways, as I mentioned at the start this isn't a big issue, just an annoyance really.
Edit:
Should probably mention I am running Win 7 Pro x64.
Edit:
