Super budget gaming rig for friend 500$ MAX
Shade340
Okay now that my friend has learned that im building a computer he has decided on that he wants to one too. (He has a crappy old emachine) So is possible to build a gaming rig for 400$?
Preferably AMD with ATI GPU
Shade340
AMD Athlon X2 7750 Black Edition Dual Core Processor Socket AM2+ 2.7GHZ 3MB 65NM 95W Retail Box
Usually ships in 1-2 business days.
In Stock 35688 $79.99 $79.99
Western Digital Caviar Black 640GB 7200RPM 32MB Dual Proc 3.5IN SATA Hard Drive OEM 5YR Mfg Warranty
NCIX.com SURPRISE SPECIALS!
Available in limited quantities only, with a limit of 1 per customer. Hurry! No rainchecks or Price Matches for these items are available after limited quantities are sold out. Note: Your order for these items are counted only after you've completed your purchase.
In Stock 34286 $68.88 $68.88
Corsair CMPSU-400CX 400CX 400W ATX 12V 30A Power Supply Active PFC 120MM Fan
In Stock 33357 $55.99 $55.99
LG GH22NS30 Black DVD+RW 22X8X16 DVD-RW 22X6X16 DL 16X/12X 2MB SATA OEM
In Stock 32234 $27.98 $27.98
Antec Three Hundred Mini Tower Gaming Case 300 ATX 3X5.25 6X3.5INT No PS Front USB & Audio
In Stock 29812 $62.98 $62.98
NCIX.COM $20 Gift Card *Pre Activated*
FREE GROUND SHIPPING FOR THIS ORDER!
In Stock 29060 $20.00 $20.00
Corsair XMS2 TWIN2X4096-8500C5 4GB 2X2GB PC2-8500 DDR2-1066 CL5-5-5-15 240PIN Memory Kit
In Stock 32608 $79.99 $79.99
Gigabyte Radeon HD 4850 625MHZ 512MB 1.92GHZ DDR3 PCI-E CrossFireX DU-DVI-I HDCP HDTV Out Video Card
In Stock 33156 $119.99 $119.99
Gigabyte GA-MA770-UD3 ATX AM2+/AM3 AMD770 PCI-E16 2PCI SATA2 RAID 1394 HD Sound GBLAN Motherboard
In Stock 35762 $83.99 $83.99
With price match and mail in rebates its 530.79 with free shipping without tax
JD
Toronto, ON
Pretty high-end stuff for a $500 build...
That RAM definitely its a rip off. Grab some G.SKILLs, they're like $55. DDR2-800 would suffice, though I think DDR2-1000 is about the same price.
Could drop the HDD down to a 320GB or 500GB. Unless there's still stock available at that price.
ImmaPC
Burnaby, B.C.
+1 for jdrom17.
IMO if you really, really want to do a budget build, get one of those low-end cases that come with 450/500W PSU's, rather than spend over $50 for a 400W alone. Yeah yeah, I know there's the quality issue with the OEM PSU's already. However, I've bought and built multiple machines using those PSU's, and none have ever failed on me. Never. You'd probably save at least $50 right there, put it towards...a better mobo? GPU?
Realityshift
Fort McMurray, AB
E5200 stomps those 7750s as well for the same general price for platform...
NCIX.com - Buy Gigabyte GA-EG31M-ES2L mATX LGA775 G31 DDR2 1PCI-E16 2PCI SATA2 Video Sound GBLAN Motherboard - GA-G31M-ES2L In Canada.
NCIX.com - Buy ASUS P5KPL-AM-SE LGA775 mATX DDR2 G31 PCI-E16 PCI-E1 PCI Video Motherboard - P5KPL-AM-SE In Canada.
NCIX.com - Buy MSI G31M3-L V2 LGA775 G31 mATX DDR2 PCI-E16 2XPCI SATA LAN Sound Motherboard - G31M3-L V2 In Canada.
All of those are under $70 and have been used multiple times to overclock E5200s to 3.8ghz and beyond.
NCIX.com - Buy Intel Pentium Dual Core E5200 Dual Core Processor LGA775 2.5GHZ 800FSB 2MB Retail Box - BX80571E5200 In Canada.
Roughly the same price as the 7750 but a MUCH better CPU, all the 7750 is is a chopped up Phenom I...
I also agree with IMMA, for a higher end build id NEVER look at one of those case+PSU deals, but in this case you will probubly be well within the max wattage of an OEM PSU.
NCIX.com - Buy NCIX XION2-BK Black ATX Mid Tower Case 4X5.25 2X3.5 5X3.5INT 2X120MM Fans 450W W/ LED Fans & Window - NCIX-XION2-BK/GN In Canada.
Not the greatest cooler but should be able to handle that system without any issues.
NCIX.com - Buy Logisys CS206BK Black ATX Tower Case 4X5.25 1X3.5 5X3.5IN W/ 480W 80MM Rear Fan Front USB Audio - CS206BK In Canada.
You MIGHT need to use one of those 4 pin to 6 pin PCI-E connectors with the PSUs but other then that Id say it would be fine. Take the money saved and throw it at this, or just leave as is and take the savings.
NCIX.com - Buy Powercolor Radeon HD 4870 770MHZ 512MB GDDR5 2XDVI PCI-E Video Card - AX4870 512MD5 In Canada.
Also better ram for cheap...
NCIX.com - Buy G.SKILL F2-8000CL5D-4GBPQ PC2-8000 4GB 2X2GB DDR2-1000 CL5-5-5-15 240PIN Dual Channel Memory Kit - F2-8000CL5D-4GBPQ In Canada.
I also agree unless you can get yourself that hard drive for the listed price garanteed then id just grab a different drive, although the WD blacks are really fast they arent going to amount to any gain in FPS which from what I can tell is what your looking for as its listed as a budget gaming build. You should probubly answer the sticky questions about your build in your original post so people like us know what your using it for ect.
geokilla
Toronto
Canada Computer has the OCZ StealthXStream 500W for $30AR. Excellent PSU so if you're in GTA, go grab that.
Shade340
Really? thanks
Okay I live like 10 minute bike ride from my CC so I will go pick one up thanks!
Soultribunal
Mississauga
The only thing I don't agree with RS, is that XION PSU combo deal.
They are garbage, it may say 450W and you'll be lucky if it gives you 220W before it gives up the ghost.
Never use substandard PSU's, unless you like throwing away money.
ST
