Superpi 1m Benchmark Competition
Killswitch
Sault Ste Marie, Ontario
just out of curiosity what were your temps at for your benches killswitch?
At 3.8Ghz with 1.5V and "Auto Xpress" and "CPU Tweak" on, I haven't seen anything over 50*C yet under full load, and it idles at about 36*C. This cooler is wicked! I use Core Temp for my readings. It seems to be the most accurate.
I only run those settings for benches though. I'm usually running the CPU at 3.7Ghz with 1.475V and those other 2 features off for even better temps and more stability.
Jonwall
Belleville, Ontario
Superpi 1m 17.830s
Phenom II [email protected]
Asus M3A79-T Deluxe
Win7 x64 build 7057
I also got a run of 17.800 but it rebooted just as i tried to save the screenshot :( Also got several runs of 18.1xx running at 3.8ghz with a 200mhz fsb and the nb and ht running at 2.4ghz, if i had some decent ram i would likely be able to get lower times than this
Dogger1
Deep River Ont/Omaha NE
Pushed it a tad more.
[FONT=&quot]9.851 secs
i7 920 @ 4185MHz - on air
6Gb Gskill DDR3-1600 @ 600MHz 9-9-9-24
ASUS P6T6 WS Revolution[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]
[/FONT]
CMetaphor
Quadfather
Montreal, Canada
It's no i7, but here's my "Budget OC" Box. Hit the FSB Wall Reeeeeeaaaallll bad above 320Mhz FSB.
14.430 secs
e5200 @ 4000MHz - Air (IFX-14 w/ 3x Scythe 140mm/104Cfm)
4Gb Gskill DDR2-1000 @ 800MHz 5-5-5-15
Gigabyte GA-EP45-UD3P
somecanadianguy
somecanadiancity
Here's my best time... settings are not stable, but it did handle 1m and 32m
so that's all that matters for this, right?
:canadianwave:
superpi 1m score 09.843s
CPU: i7 920 @ 4.2GHz
RAM: Corsair XMS3 3 x 2GB 1333
Motherboard: Gigabyte ex58-ud3r
sheepdogexpress
Regina
Just a hair faster than you redlion.
8.705s
Looks like you are on phase.
That 222bclk wall is a bitch. I am on water and I can bench pretty much everything at the max speed, aside from wprime 1024m.
These gigabyte motherboard along with anything but a classified has this weakness.
LionRed
Dargaville, New Zealand
Good Job Sheep! :thumb:
Yes..on phase just got it a week before getting i7. Everything installed/insulated...learning about the i7 overclocking etc. I got to 223 once...but I forget how I got it :doh:. Prolly lucky boot.
I am on vacation in Saskatoon atm...so no tweakin my SuperPi score. Will be at it again coming sunday or monday.
sheepdogexpress
Regina
Yeah I want to go phase too. Problem is this bclk wall makes it pointless unless I get a new processor with a higher multiplier or a new motherboard.
