Gallery Supersonic ping pong ball
BrainEater
Calgary
Try it with a golf ball muhahaha
I can suggest crazy $IIi7 cause I'm miles away.
A golf ball would not move.
This only works because it's a ping pong ball.It's a thrust thing.This is pure physics.
When the vacuum is going it's about a 15 psi differential.A ping pong ball has a diameter of 1.57 inches.That's an area of ~ 3.8 square inches.15 psi X 3.8 square inches equals 57 pounds of thrust on an object that weighs 2 grams ! (yea my maths bad but...)
That over 10,000'G's of acceleration.
:haha:
IRQ Conflict
Drayton Valley, AB
46g for a golf ball which is 23 times as heavy. I'm not sure but the outside circumference is close is it not? So 23 x 15 = 345psi or more properly 2.42 inches of mercury.
For you to get a golf ball to do roughly what you did with the ping pong ball it would take compressed air @ 345psi or a vacuum @ 2.4in mercury @ 0c. To get it supersonic, well that's a whole other ..ahem ball game.
I was thinking, we could rent one of these for an hour. :biggrin:
BrainEater
Calgary
Ah shitballs !!
My Vacuum pump is only doing -0.75 bar right now......that ain't good enough.
The vacuum thang is very important in this experiment.The terminal velocity of a ping pong ball is really slow.Low mass , high drag.......The only way it'll go 500 mph is in a vacuum....
The vacuum pump is going in for service monday , but really it's not good enough......it's right on the cusp.......The first shot I did that worked was -0.82 bar.For this to work properly you really want -0.99 bar.
I'm messing aroung with making ABS c-d nozzles.
:thumb:
IRQ Conflict
Drayton Valley, AB
I dunno. Maybe the trusty potato cannon would be a better/funner project?
Edit: I tried converting barometric pressure to inches of mercury with negative values. If you'll forgive the pun, it doesn't seem to add up. -0.75 bar = -22.15 inHg ?
Isn't vacuum better expressed as a positive rather than a negative? My brain doesn't want to go there I guess.
Father Fuzzy
B.C.
Not sure what your doing Braineater(as usual)
but you got my interest(as usual)
Subbed!
BrainEater
Calgary
Yep......looks about right.
Bars are a depreciated unit , we're not supposed to use that unit anymore , it's just that it's how a lot of vacuum equipment is labled.
1 Bar ~ 1 atmosphere at sea level on Earth...
It's 14.5 psi and /or 29.5 inHg.
-1 Bar is perfect vacuum......so like -30 inches of mercury.....
:thumb:
ps :
this project appears to require more suck... and less blow. :ph34r:
Absolutely.The pump is sucking at sucking !
:rofl:
clshades
Big White Ski Resort
a perfect vacuum is only theoretical anyway... -.99 will do donkey :)
What you need is a quick release valve on the back end so you don't have to keep taping it. I would suggest solid core ABS too that cellular stuff is garbage... either that or use steel or copper pipe :)
I have access to a threader if you need.
-speaking of which we should run a pipe for your BBQ and turf the propane tank ;)
Stukka
Surrey, BC
The solid core ABS clshades is talking about is called abs dwv. You may or may not be able to find it at home depot though.
