Surround audio problem?
TimTheEnchanter
This must have something to do with channels or audio configs in windows... but somehow i can't seem to be able to change anything... Seems like we cannot configure spdif output?
My HTPC has optical audio output to a Pioneer VSX-520-K receiver. I do not get surround sound with certain type of files : avi files, music files, and even certain dvds. Some dvd even mention 5.1 audio but do not deliver.
Any ideas on the problem?
lowfat
Grande Prairie, AB
Unless some sort of compression is added (dolby digital, DTS), SPDIF can not output more than 2 channels. Most DIVX movies & music have 2 channel soundtracks. Some soundcards can encode and compress the sound in to AC3 though.
I bet if you were to play an mkv w/ a DTS soundtrack would get 5.1 no problem.
TimTheEnchanter
I see... well what are my options? I do have a Auzentech X-Fi Forte i can swap on the HTPC. I also have HDMI output (which would force me to take away the old video card though...)
lowfat
Grande Prairie, AB
Well music is suppose to be 2 channel so you would need to upscale it to 5.1. I know the Creative drivers that are used w/ the Forte can do this.
Arinoth
Halifax
I've never found that with my optical out lowfat. I've used two different onboard and an older creative card optical to my receivers and both have outputted in 5.1. Mind you i only use winamp for my music and vlc for video so they may do something behind the scenes that i'm not aware of. All i know is that all my music players in 5.1 and all my videos output in 5.1 as well.
Tim what applications are you using for playback?
TimTheEnchanter
I mostly aim the best results for movies.. so i guess i should just go with hdmi... that would work out well, right?
I use XBMC and VLC.
Arinoth
Halifax
As long as its 1.3 you'll get full audio out, though what playback applications are you using?
Arinoth
Halifax
What signal does your receiver report receiving from your pc?
I get full 5.1 playback on my htpc connected to my receiver via HDMI however i will look at the settings to see if there was anything extra i had to do
Here are my settings for XBMC
System > Settings > Audio output
audio output - HDMI (for me)
Speaker Configuration - 5.1 (manually set it to that)
Dolby Digital capable receiver - enabled (mine is)
DTS capable receiver - enabled (mine is)
Audio output Device - WASAPI: ATI HDMI Output (what the pc primary audio output to xbmc)
For my PC connected via optical from onboard
Sound -> Digital Audio -> Supported Formats
DTs audio - enabled
Dolby Digital - enabled
lowfat
Grande Prairie, AB
His can play 5.1 if he has a DTS or AC-3 compressed soundtrack. Like I said above some soundcards can encode and compress all audio in to AC-3. And if your playback sofware is set to upscale the audio then you very well may get audio out of all of your speakers w/ just a 2 channel soundtrack.
As an audio purist :)haha:) though, I prefer my 2 channel music to play in 2 channel. If you have movies that only have 2 channel audio, your receiver can definitely do a better job at upscaling to 5.1/7.1 w/ PLIIx.
