Task Manager is 30 years old and stiill an important tool
ZZLEE
KANATA
Dave wrote it and he gives some insights to it's use . Some cool controls and trivia . :)
It's only a little faster, but it does sometimes get you access to the task manager even when other shortcuts don't respond.
I somehow never knew that was the TM shortcut. Had always gotten to it via ctrl+alt+del :o
The difference is that the crtl+shift+esc opens it directly, while ctrl/alt/del requires selecting task manager from a menu.
I personally have just been using right click on the start button to access it.
Yup, I get that. I use ctrl+shift+esc all the time. That is what I meant by it being beneficial when other shortcuts don't work.
