Completed The Crippled God. Scratch Open Frame Build.
lowfat
Grande Prairie, AB
Better pic w/ the PSU shroud
On to installing the LED strips. Using WS2815s for the ARGBs.
Didn't like how the strips looked nor the white UV LED strips. So making some shrouds for the LED strips to clean them up.
Found that the single ESP8285 couldn't do both the UV and ARGB due to firmware. So I decided to add another ESP8266 for the ARGB. Designed and printed a small case for it.
Left a window for the wifi.
Fitting them in the case. Wiring is going to be tight but should be manageable. Using ESPHome for the ESP8285 for the UV LEDs and WLED for the addressable RGB.
Only printed part in the case I didn't design. But they worked so much better than what I was planning.
https://www.thingiverse.com/thing:2731180
danmitch1
Lol, for a spit second it looked like you had a piece of carpet on the bottom of the case.. then I realized it was on the floor with an open bottom... Nice work again!
