Work in progress The Crippled God. Scratch Open Frame Build.
lowfat
Grande Prairie, AB
Notice cables on right. Each column changes colours but the rows are the same.
But I messed up on the 8-pin EPS and I changed both column and row.
Because of it I would have had a duplicate colour visible on the front. I tried to fix it a few times but I ended up just making it worse. So I redid them from scratch. :(
Gave it a bit more slack @ the mobo end, which I think looks better. You can also see the first UV LED stripe installed. Also seen I've installed the PCIe cables and have removed the combs.
And the backside. I decided to use a couple of connectors for VGA in case I use a different GPU and it has a different connector setup. But limited to 8+6. Guess I should have done dual 8, but hindsight is 2020.
