The great case debate...(sort of)
Matthecat
Hey all. I can't really decide what case to get for my first build. I'm debating between the 600t SE, the NZXT Phantom and the HAF 912. I'm looking for something with good looks and that has great airflow. It needs to keep the GTX 560 TI sli config I'll get cool and I want it to fit my Hyper 212+ cooler. I might even upgrade to an H50 cooler for more OC reliability. I like the NZXT Phantom case the most for the looks. The white and red configuration looks amazing. The 600t is not bad either. I'm not too fond of the HAF 912 but if I get it I'll buy 3 red LED fans to put on the side, front and top and I'm curious to know how that would look. I wouldn't mind getting any of these cases really, so airflow and temperatures will be the deciding factor. If the Phantom has good airflow then I will get it. Without added fans how is the airflow in the Phantom, and is the LED fan it comes with red or blue. If it is blue then it will be a big turnoff because I don't want my red, white and blue case to look like a christmas tree. I know these are a lot of questions but I do want to make sure that this case will last me Thanks guys.
enaberif
Calgahree, AB
Of those cases I'd get the Haf 912 if you are on a budget and the 600T if you can spend a bit more. I fell in love with the 600T aside from one small thing and its a REALLY great case.
Matthecat
Can I fit a fan into the side mesh of the 600t SE? I've heard that the 600t isn't the best case when it comes to cooling. Would that extra fan or two make a difference and would it interfere with the CPU Heatsink?
enaberif
Calgahree, AB
600T has plenty of airflow.. It has two massive fans going through that system :)
Matthecat
Sounds good. I'm going to get some Xigmatek red led fans to replace the white ones since I really like that look. I think they Xigmatek ones will fit because they are 25mm thick like the stock ones. Ty for the help and extremely fast responses :)
_dangtx_
mtl
the haf hands down. nothing in its price range can take it :)
and its a solid mofo too! built one for a fiend, his kid sits on it lol.
Matthecat
Lol^.
I've decided to go with the 600t SE because I love it's looks and colour. I was just wondering, I will get the p8z67-v PRO motherboard. Will i be able to add 4 120mm Coolermaster R4 fans to the mesh side of the case? If so where would I connect these? thanks.
