Finally took the time to install the Insinkerator Evolution Excel I bought months ago. Drain is a tad more sloped than I'd like, but it won't harm it and I was tired of hacking the plumbing apart. The drain is not perfectly plumb on the other sink either, the original builders built the p-trap so low that scrapes the bottom of the kitchen island cabinet and you have to force the piping out of the way to connect. There's not enough piping coming out of the other side to cut and replace the p-trap easily either. There were some challenges with the dishwasher hookup too, but cutting off the original end connection of the hose and clamping an aftermarket adapter worked.
Had planed on using all new piping, but the threaded flange on the original p-trap were different than the ones available at home depot. Just slightly narrower, enough that the new ones couldn't thread onto it. In the end I just cut the pipe and popped a union on and did new pipe on everything past the union.
The happy part is this thing is
quiet. Like the faucet is louder. I suspect it must have noise insulation in the housing which would explain the chonky-ness and quiet. Also no leaks and fired up on the first try which is always a plus.
