AkG
- Joined
- Oct 24, 2007
- Messages
- 5,270
Mid-Speed Fan Performance Results
2.6GHz
Once again we see exactly how great a fan the Frio comes with as it once again beats our standard fan (this time the venerable Nocuta NF-P12) when both are running at the exact same speed. The fact that Thermaltake includes TWO of them is astonishing. As for the Frio in single fan configuration, a solid third place finish is nothing to sneeze at. The Frio obviously is very flexible as it continues to impress.
3.42GHz
It seems while this Frio is flexible enough to run with a much slower (and MUCH lower static pressure fan) than it was designed for, it isn't quite as good at it as some of the others like the mighty Prolimatech or even Titan Fenrir.
3.8GHz
As expected the Frio did slip down the charts as the heat was increased. Funny thing is it landed in the exact same position it did when paired with the Scythe S-Flex G which speaks favorably of the design of this unit as the P12-1300 and the S-Flex G are nearly on opposite ends of the fan spectrum.
2.6GHz
<img src="http://images.hardwarecanucks.com/image/akg/Air_Cooling/Frio/p12_1300_26.jpg" border="0" alt="" />
3.42GHz
<img src="http://images.hardwarecanucks.com/image/akg/Air_Cooling/Frio/p12_1300_34.jpg" border="0" alt="" />
3.8GHz
<img src="http://images.hardwarecanucks.com/image/akg/Air_Cooling/Frio/p12_1300_38.jpg" border="0" alt="" />
