Thinktank Revision 2.0
Status
Not open for further replies.
BrainEater
Calgary
Ok.
I promised the the thinktank 2.0 worklog to Hardware Canucks.
Here it is boys and girls.
Preface ~
For those of you that don't know , About 4 years ago , I created a submersion cooling based case/computer.
The machine , while completely under liquid , ran fine , but there were no spectacular temps.
I was dissapointed.I am going to rectify the situation.
Thinktank Revision 2.0 specs ~
Intel core 2
Mobo yet to be determined ; Asus striker if it'll go
Muskin extreme redline ddr2 pc8000 ( micron d9gmh )
Cheepo video card at first..
- The entire motherboard assembly will be Submerged in 99% Isopropanol alcohol , that is being cooled with dry ice.
- The system will consist of 2 separate tanks , the first being the original thinktank 'tank' (after modifications) , the second being a 'resevoir' for dry ice and alcohol.
- The resevoir tank and all associated piping will be insulated via the Vacuum jacketing method.
- The whole system is being designed to go below -100 C.....We shall see ....
Onto the very first pics !
Original Tank on half rack.This is the 'case' :
Here's the open rack with the tank ;
Now the two tanks and the vacuum pump. ;
What is vacuum jacketing you ask ?
Here's a shot of a vacuum jacket pipe :
It's a pipe inside a pipe , and you maintain a vacuum between them.The resevoir tank will basically be a vacuum dewar , same thing.....best insulation around.
I might make the piping from stainless , I'm not sure yet.
:thumb:
more right away !!
sswilson
Moncton NB
:shok::shok::shok::shok:
Ummmmm..... how good is your house fire insurance??????? :)
BrainEater
Calgary
Hehe
The entire system is being designed with that kinda thing in mind.
The whole half rack is being setup to run a positive pressure nitrogen atmosphere,,,
Don't worry bout the Isopropanol tests...they'll be fine.
it's the methyl / diethyl ether tests that worry me...(assuming the hardware survives)
heh
:thumb:
vinister
Vancouver
Wow if they find your house in ashes they will assume you were building a computer-ignited bomb. You sir are crazy!
t0m
bc
holy sh:censored: dude...good luck and be careful...cant wait for more :thumb:
BrainEater
Calgary
Hehe.
No I'm not crazy , and yes I have fire insurance :haha:
Thanks for the words of concern.
Let me assure you however , I do actually know what I'm doing.Safety is my #1 concern , believe me.The entire machine is going to be surrounded by nonflammable gas , and I'll be building active solvent recovery systems.Even the blanket gases are going to be properly ventilated.
I managed to get my first vacuum jacket pipe put together today.
Step 1 : 1/2" and 1/4" soft copper tube ;
Sized and straightened ;
I'm using flare unions on this sucker....metal to metal .....
The full monty :
Downstream end :this is where the vacuum connection is made....
Tank end :
Hopefully i'll be soldering part of it together tonight......But it need's a 90 degree bend , which im werkin on......
:thumb:
Cptn Vortex
Vancouver
My jesus. I love the 25U rack though, been thinking of getting one and a few rackmount antec cases
BrainEater
Calgary
Thanks man ! ...Racks are great.
This one actually has a story too.It's an original series Q-sound processor rack , that I've repainted in my clans colors..... It usta be a semi white cabinet , but I saved the plaque ;
I've soldered the first vacuum jacket pipe..... ;
Tank end :
Drain/vacuum end ;
It's certainly not perfect , but it's not bad for my first try , I think newayz.....It is getting an exterior 'seal' coat , so the solder joints are mechanical only ...
This is only a 1/4 inch line tho.....The main circulation lines will be 3/4 inch ID minimum....1 inch if I can do it.....But the piping will be a challenge for sure !
More in a few days .
:thumb:
BrainEater
Calgary
Yea baby !!
Ok.......I am taking the 'backplate' from the original thinktank to the welder's. :
Every hole inside the rectangle will be welded shut.....I'll be drilling new holes.
I have removed the top from the keg.
First I'd like to thank Mike and Ryan from Wildrose brewery In Calgary.Thanks for getting me the tank boys , I owe yah a beer....hahaha
Pressure let out , start hole drilled :
Sawed off......same jigsaw from thinktank 1....pooor f'in thing ....hahah
Top removed , ready for next stage ;
I have a bunch of glass ordered too.I'm making the original tank into a 3 wall Ln2 (hopefullly) container..
The tank shown will be going into another stainless steel tank just a wee bit bigger.......for the vacuum jacket.....
:thumb:
Status
