Thinktank Revision 2.0
Status
Not open for further replies.
BrainEater
Calgary
Hehe......thx guys :biggrin:
I have made some progress.I had the day off today , so I went hunting at the local scrapyard.....Found 2 amazing buys.
I got the inner tank for the storage dewar :
I have necked it to be just a wee bit taller than the outside tank....
Nearly complete dewar : all thats required is to seal the two tanks together at the top.The vacuum connection can be seen as well......
I am designing my own pump.I believe it'll be cheaper and easier to maintain than most commercial solutions.I should have some prelim. pics of this up soon.
:thumb:
snoosebum
Mackenzie BC
A bit out my depth... but I'm not sure why use alcohol and dry ice? Is the goal to keep it warmer than -50C to avoid damaging the board? If not why not fill your tank full of liquid nitrogen? it seems like it would be a lot safer.
BrainEater
Calgary
I'd like it to go colder than -50.
Here's the deal ;
I can't use straight LN2.I'm pretty sure if you just poured LN2 on a running motherboard it would immediatly die.Thermal shock is no joke.
By using Isopropanol and dry ice , I can bring the temp down reasonably slowly, thus minimizing the effects of thermal shock.
Secondly , the physical requirements of a tank/recirc system designed to handle LN2 is a lot more mechanically demanding.And expensive.
I'm really not sure LN2 would be any safer.While using flammable solvents seems really dangerous , in reality , flammable solvents are used every day in industrial applications.As long as the correct protocols are followed , it's really no big deal.
:thumb:
BrainEater
Calgary
sure. :biggrin:
Before I give you a sneek peek , let me explain why updates are slow on this sucker.A good portion of the materials required for this are very difficult to source.I Just found 'proper' borosilicate glass :
TecniGlas
I am waiting on quotes.It might be $$ so we'll see.
I have also found the 'exteriors' for my vacuum jacket lines.
here's yer pic :
I have every part (computer wise) except the video card.
I am working on the 'inners' for the VJ lines.
Once I decide on proper inners (and have pipe sizes etc),I can start worrying about the pump in earnest.
This is the hard part.
Just try and spec out a 'cheap' pump for alchohol at -80c.No such thing exists.heh...I'll be using the soviet method for building my own pump , I think....The 'blood and thunder' way assures results. I should have some prelim pump building pics soon.
:thumb:
BrainEater
Calgary
Quicky update :
I have heard from the glass supplier.Looks like about 500$ for the borosilicate glass to make the inner tank.That's more than I had hoped , but I don't really have any choice.It is the best material.
I think I can swing it .. :thumb:
BrainEater
Calgary
ah yea , it's more than I wanted to spend..I take my 'projects' very seriously tho.The thinktank is already worth thousands of dollars and taken thousands of hours of my time.
The original 'thinktank' is a fishtank, for all intents and purposes , however I'm about 98% sure if I fill it with -80c liquid , it'll shatter.That would be bad.
Borosilicate glass is the correct material for this application.Therfore , it's 500$ well spent.
:thumb:
klaiboi
Montreal
BrainEater i hope you get this to work and then set a new world record for greatest overclocks lol
I want you to set the record on like 10 different CPU's lol
Eldonko
Calgary, AB
What is the freeze point of polymer capacitors? I know you will have issues with normal caps around -30 to -50.
Status
