Thinktank Revision 2.0
Status
Not open for further replies.
BrainEater
Calgary
Hehe.
quicky update ;
I've moved the rack into the garage (test area) .
On that note , I gave it a quick repaint ;
Taped ;
Painted ;
Final ...(test 1 of 200 prolly :haha: ) ...assembly has actually started.
I have a lot to do still , but I'm very close to the first leak tests.
:thumb:
3.0charlie
Laval, QC
Is there anything you can't do?
mmmk, West jet, YUL-YYC... checking...
Since I did YUL-YTZ yesterday...
BrainEater
Calgary
I'm hoping to have a better handle on when stuff is gonna happen right away.
Gimmie 2 weeks , I'll be able to nail down a date.
:thumb:
misterlarry
The Woodlands, Texas
Hope I'm back in Calgary when you fire this puppy up. Gotta head to Houston tomorrow for about ten days - should be around the week after that though.
Will there be a brown-out when Thinktank 2.0 hits the power grid?
:thumb: :thumb: :thumb:
BrainEater
Calgary
Haha nope .....doesnt draw that much power.....bout the same as the first thinktank actually , 1200 watts mebbie ? ....
Backplate corner bead of silicone : yes , it's messy , but yah won't see it.
Got the Lexan for the pump housing ;
I'll be putting that together this week , as well as putting in the foam bits on the inside of the tank proper.
:thumb:
BrainEater
Calgary
Got the pump mount done ;
wewt !!
Taped :
Inside painted ;
I should be siliconing the lexan on later tonight....
:thumb:
3.0charlie
Laval, QC
Jeez.... a pump mount and bracket in .25" steel... do you have an idea how strong that thing is?
:thumb:
cwestwell
NWT
jeez...you gonna be mounting a pump in that or a friggin 4 banger motor.....seriously that is one hell of a mount.
Status
