Thinktank Revision 2.0
Status
Not open for further replies.
FiXT
Hall of Fame
GVRD
keep in mind that with distilled water, or any water for that matter, it will rather quickly increase in conductivity. Given that the distilled we were using had been opened an likely re-ionizing for a bit.
So i'm not surprised really that it was that high. I wouldn't expect a freshly sealed batch to conduct near that much. Off the top of my head I can't quite recall norm of fresh/pure distilled
We couldn't even run a computer for an extended period of time in the same batch of distilled, as it gained conductivity from the components running it. Had to use a fresh batch for each run.
BrainEater
Calgary
Absolutely.
Both water samples exhibited 'dropping' measurements as far as resistance goes......and lets not forget about dielectric constants/permittivity etc....
I'm either going to dunk a mobo in kerosene , or distill off some anhydrous IPA.....I've got the magnesium for it's prep./.....we'll see.
:thumb:
Eldonko
Calgary, AB
I have a friend that is a chemical engineer, let me consult with her and see if she has any advice.
Arinoth
Halifax
Kerosene huh, sounds even more dangerous, I like it!
Nothing like using a combustible liquid with something that can get hot, lol. Next we'll see him thinking about using the coolant oil that is used in electrical transformers :whistle:
TopDogZero
Ajax, Ontario
First congrats on the maiden run.
The result of the mobo tests was that nothing error'd until the Iso interacted around the CPU
SO is there no way to seal the CPU socket to prevent ISO from getting to the pins as I assume that's where the problem is. Or do you suspect the ISO will cause more problems to other parts of the setup later on.
Eldonko
Calgary, AB
It's not just in the socket, the whole vreg area shorts out. Instantly when you full submerge.
Status
