- Location
- Langley, BC
Epoxy is hard enough that it won't compress when you try to put the screws in after it's cured. Drilling and gluing in a 1/4 or 3/8 dowel would be the best option.
I just put 1 or 2 in the hole and drove the screw in, don't recall using glue. The other 2 screws in the hinge were tight though, it was just 1 that wasn't so I didn't think it was a big deal.I've also seen suggestions for glued toothpicks forced into place w/ a small diameter nail.
Dowels would be the best option. The problem might be finding a good hardwood dowel that's also accurately sized. Imported dowels might be metric size or poorly size and the drill size is Imperial. Test drill in a scrap of wood and check.Any recommendations on a "wood filler" product that can be used to fill door hinge screw holes so that I can drill a pilot hole and have it take the screws securely?
Sounds like the most recommended solution is to drill out a hole big enough to accept wooden dowels and then glue those into place.... that sounds like a lot more work than finding something like an epoxy filler that would work..........
There's plastic wood anchors too if you search Amazon, unsure if they work well. Similar to a drywall anchor.I'll probably end up going with the dowels even though it feels/sounds like a lot more work than it should be.
Today, the recipient said she rec'd the package today (unopened), no duty applied.If labeled as a gift and valued at say $25 (which is undervalued, of course) I don't think there'd be any issues.
I tend to buy the pails of primer even with a paint and primer in 1 then any tinted gallon cans after that tend to cover a lot better and go further.Is it a bad idea to just refresh a 2/3 full 8 yr old tub of drywall goop?
Didn't have to add any water, just gave it a good stir with an electric drill + a paint stir attachment and it seems fine. Just had to remove the large hard chunks which fell in from the side.
Oh, and while I'm at it, how bad can these big tubs of interior paint be????
It's super cheap at costco when compared to buying by the gallon from the hardware store?
