Tiny countertop dishwasher anybody?
sswilson
Moncton NB
I've seen a few countertop dishwashers over the years, but nothing this small.
Neat looking unit, but here's my question.... it's got a built-in water reservoir so it doesn't need to be plumbed into your existing system (or attached to the faucet like the full sized "portable" ones), but where does the waste water go?
Lysrin
Nova Scotia
Neat design for that IKEA-cool-sheik decour :) About the waste water, if you look at 17 sec into the video, does that look like a waste water tube going into the sink? That would seem to be the simplest solution; a waste water tube into the sink when it's running.
Izerous
Folding Team
Edmonton
There is an outlet hose if you bounce through the video that you can run to your sink with a weight on the end of the hose. And seems to rely on proprietary container of soap that you have to load it with for it to run that you have to keep buying to use it.
Soultribunal
Mississauga
Wonder when it will:
A) Have RGB and connected to Synapse
B) Get Noctua Colours
That would sell millions then!
On topic, that is very cute, for smaller apartments and Condo's where a full size one might be an issue.
-ST
Lysrin
Nova Scotia
I'm sure if it becomes popular enough, someone will make a refillable container option. Same as what happened with k-cups and the Keurig coffee makers.
