Tri Sli GTX 280's - Porn For Geeks
rjbarker
Courtenay, B.C
:thumb:
Something I neglected to consider is the Silverstone Case has a bottom mount Fan, therefore no way to utilize the 4th GPU Slot for PhysX Card......:doh:
Oh Well....
cheers fellow Canuckers:bananafunky:
rjbarker
Courtenay, B.C
I take it the HX1000 is having no problems? What's it pulling from the wall?
So far so good..no anomalies.
Not sure what it is pulling from the wall...or how to check this, it is a tad warmer, but seems alright. So far I have run Vantage 4 times w no issues...hopefully it will be fine. I would guess under full Vantage Load I'm around 900W with all the Fans spinning away (7 x 120mm / 1 x 60mm / 1 x 40mm)....
Was going to drop my I7 OC from 3.83 down a bit, but seems ok.
