Triple Channel DDR3 RAM...?
mlauzon
Age
43
Toronto, Ontario
Soultribunal
Mississauga
I, personally have always Used Corsair or Patriot RAM (Corsair in the last 3 years at least now) with not one issue, problem or dead chip.
I think at this early stage for Triple Channel Ram, its subjective to which one is best.
If I had the choice, I'd put Corsair in. But that might not be the best one out there.
I haven't used anything but in a few years so...my opinion might be bias.
Regards,
ST
Chilly
Ontario
Website
mirthful.ca
I'd go with the Mushkin, better timings at the same clock. Also, you can't forget the great customer support from them.
Mushkin all the way IMO! :thumb:
rjbarker
Courtenay, B.C
Mushkin are great.....all you have to do is take the time to read some Posts in the Memory section of this Forum :rtfm:
Chilly
Ontario
Website
mirthful.ca
rjbarker, rather, Bob, you may wanna check, but I'm pretty sure that your C:\ drive isn't open to the interweb tubez. :haha:
mlauzon
Age
43
Toronto, Ontario
