Tritton Wireless AX 180 Univesal Gaming Headset Revealed
FiXT
Hall of Fame
GVRD
Mad Catz Interactive, Inc today announced the launch of the AX 180 wireless gaming headset being launched under the Company's TRITTON gaming audio brand. Based upon the critically-acclaimed wired AX 180, the new wireless TRITTON headset uses 2.4GHz wireless technology to free gamers from wired constraints, allowing total immersion and freedom of m... [ Read full article ]
FiXT
Hall of Fame
GVRD
Hurray for wireless headsets!
I've been using the Creative HS-1200 wireless unit because there really isn't anything else out there intended for PC :(
This looks like it could be a worth while replacement.
SugarJ
Folding Team
Langley, BC
Warning for double post. :haha:
J/K. It looks like it has a wire to the "portable control unit", which is meant to be hung on your belt? Any pics or links of the whole setup would be appreciated.
Caldezar
Edmonton Area
I'm currently using a wired Tritton AX180, and I'm less than impressed. I've had it for maybe 3 months and its literally falling apart. Three screws have simply fallen out of the frame. When I try to screw them back in, I've come to realize either the threading inside is stripped, or broke altogether. This is causing the hard plastic frame of the headset to start falling apart. And I treat my gear with EXTREME care. Anyone that knows me, knows I'm fanatical about taking care of my electronics.
I've sent an email and two messages via Tritton's 'live support' (which I've yet to see available) and I have yet to receive any kind of response. (first message sent over a week ago)
As much as I'm glad to see more wireless headset competition on the market, I'll avoid this one quite a bit. Bad product and bad customer support add up to 'terrible' in my books.
Nademon
Toronto
I agree with Caldezar 100% I purchased 3 of these headsets (AX 180) for myself and some family members and I'm severely disappointed. One headset being flawed could be dumb luck, two, not likely but still plausible, but all three exhibiting the same sort of problem?
I've noticed that this headset has a fatal design flaw. All three of the headsets I purchased (less than 2 months ago) are showing signs of fatigue in the plastic head-bar directly above the earphone part. it's the piece that slides in and out of the bigger padded portion which allows for size adjust-ability. the plastic is beginning to crack and show signs it will soon break rendering the headset unusable. I'm very disheartened with the customer service experience relayed by Caldezar as it doesn't bode well for me.
I think I would have to whole-heartedly advise people to stay away from this headset if you want to use your expensive headset for more than a few months before having to toss them out. At 80 bucks a pop, I think Mad Catz should get their act together and address this issue as well as make it right with the people that have purchased this inferior product.
TopDogZero
Ajax, Ontario
I was hoping these would be good but from the above statements and the fact that there made by Mad Catz I’ll stay away from them. I use the Creative HS-1200 like FiXT and fine the sound quality subpar and they are not very comfortable, but wireless is a most for me.
U
Unregistered
Guest
Ax 180
Mine broke in the same place and they are suppose to send me an updated version that does not have this flaw. This will be my 3rd pair in 8 months. If they send me the same thing am about to be pissed! Its like 10 dollars to ship each time...
J
jymbow
Guest
You can't blame Mad Catz
Tritton was recently purchased by Madcatz, so any design flaws cannot be attributed to them. Madcatz has recently (over the past three years) upgraded both their quality and customer service. Madcatz has become a quality company that should be trusted. They will produce these new headsets with their new improved quality. I plan to purchase one with the full confidence that the present is more indicative of Madcatz quality than when Tritton produced their own products.
