trying to find a decent priced 6TB harddrive
Shadowmeph
I only have been searching amazon for a 6TB hard drive to move my TV series and movies and some Documents onto , right now I have two 2 TB drives one of which only has 100GB left and also they are both plugged into my Raspi4 kodi box so I want t op[ut all my files onto one drive and plug that into it instead of having 2 drives , but I cannot seem to find any decently priced 6TB drives
gingerbee
Orillia, Ontario
will you be will to shuck the drive or do you just want to buy one out of a case, I ask cause I have always found drive shucking to be the cheaper root.
ps I have seen one at best buy for $160 but you can get 4TB you don't have to shuck from amazon for just over a $100
Shadowmeph
ok another question could I just use a cheaper prices Nass drive move all my Movies and TV shows onto it .
Shadowmeph
Now I just need to find a drive that I can plus into my Raspi4 hopefully that will work with my external HD case
