Trying to get my quad 295's all folding
SugarJ
Langley, BC
If you got those 295's from Zlojack, he never could get the 4th core working. I hate to suggest it because you're under water, but try swapping cards to see if the issue follows the card.
kruzn4evr
Ajax, Ontario
I am beginning to wonder about this one core, I've lowered the clocks in increments 4 times and now at 504/1107/999 and even paused the other 3 cores and still getting the same thing. Thing is, the core itself I believe is working properly based on benches I've done so far.
SugarJ? you mean swap out one of the pcb's to the other card?...man!!..then I'd have to drain the loop and put them both apart!...what a pita that would be! :doh::haha:
3.0charlie
Bedford QC
Troubleshooting continues.
Raise the Core back to stock speeds, lower the Ram speed this time around. Same pattern. After a few unstable machine messages, raise the ram back to stock, and lower the Shaders.
If all 3 report unstable machine messages, the card has a major problem.
kruzn4evr
Ajax, Ontario
I had the same thought, I'll mess around with it more tomorrow, as I said though, overall both cards appear to performing fine in every other aspect, benches, games etc. so I find this rather strange....if the card does have a major problem I'm gonna have to get ahold of Jack for RMA...I'm sure he'd be pleased to know it wasn't just him though..lol
fefox
Manitoba N50° 15.5944', W101° 2.2833'
My setup, Vista with the 2x295 cards, I sometimes get one job throwing the unstable_machine msg, I would delete and download a new WU.. if that didn't fix the problem, I would SHUTDOWN the machine not reset, and then power it right back up, check to make sure I all 4 desktops are available and then start the folding jobs...
thats always worked for me..
also both the blue and green LED's are lit on each card right?
kruzn4evr
Ajax, Ontario
Well SOB!!...I just had a look and only blue light is on!...they were both on last time I remember looking, which was within the last couple of days...DAM!
kruzn4evr
Ajax, Ontario
I disabled SLI in the nVidia control panel and now have both blue lights....I'll give it another try just to see what happens
SugarJ
Langley, BC
I meant to swap card positions. The card in PCI-Ex16 slot 1 moves to slot 2 and vice-versa. Just to see if it's a issue with a specific card. But I see you've identified an LED indicator issue. Power related?
