Does anyone know if it is possible to turn the power off on a (specific if possible) USB Port (preferably one that is on the MOBO rear panel vs one of the front panel ones).
I know by default these ports are left powered so you can use kybd/mouse to turn computer back on, but because I am using the USB port to power my LCD panel, when I turn the computer off or set it to sleep, the panel stays on, and without an active display, it just shows a bright blue screen.
I guess another option would be to jury rig a USB cable into the 4 pin molex and tap the 5v off from there.
