- Location
- Moncton NB
Yeah, that seems a bit much. I know I got a great deal, but that's what I paid for my NIB POE enterprise.
It doesn't have PoE+++ out, only used for an input. So it, itself needs the PoE+++ potentially. Hook up a couple PoE++ devices to it and you will need the PoE+++ in to power the switch and all the devices, otherwise you won't have enough.what stuff actually needs PoE+++ levels of power? I can see gear that needs to be outside and heated to withstand crazy sub-zero temps...but what else?
also, they need to figure out a new way to say PoE+++...like, when it becomes PoE++++, call it PoE4?![]()
I believe you're seeing this right when you click on the "VPN Server" tab right? It's taking you to the "Create New" screen as there's nothing else to show.Question for the net gurus out there......
I'm trying to configure a docker app in unraid that uses a VPN paired with wireguard and I'm having issues with connections, but now I've noticed that the CGMax appears to have a wireguard server built in with no way to turn it off?
Anybody know if this might be blocking the inbound ports from being passed, or am I just tilting at windmills?
I have one setup, so mine looks like this:
Also if you go to the Insights section, you'd see it there too if running:
