Click Image To Case Mod Store
The Lancool PC-K62R1 Factory Product Page
Portland-->Seattle sent me this sweet image of Reaper... This would be cool on the front
Let's take tour of this chassis before it gets modified!
2x 140mm exhaust fans (specs?)
140mm intake fan (Red LED)
I etched the Unreal logo into the side panel window with my Dremel and these Engraver Attachments
The top 2x 140mm exhaust grill. The vents in the top cover will be removed.
This is the Unreal faceplate for the front bezel, made from 1/8" thick acrylic, with 140mm grill.
1x DVD drive will be used... Reaper silhouette will clear drive drawer, eject...
Next step is mounting holes, prepped and painted Matte Black base coat before Airbrushed art work
Here are some of the products from Mnpctech used for this PC build project.
Most Computer Chassis will accept 1/8” diameter Pop rivets, Gripe range .092" - .125" for Computers.
Pop Rivets For Computer Cases
120mm Black Honeycomb Grills, Custom 120mm Fan Grills
Socket head stainless steel screws used for the fan grills.
M4 Watercool Radiator & Rad Grill Socket Head Screws
