Unresponsive external HDD
Inik
Montreal
Hey!
My GF external HDD is acting weird! I can't access it. It shows on My Computer but without the % of space used or anything else. It's all ok in Device Manager.
When I try to access it by double-clicking on it, the windows is not responsive and I have to disconnect it. When I try to look for it in Disk Management, it also becomes unresponsive and I have to disconnect it and reconnect it after to actually see it.
It seems we loss read access to it?
moocow
Vancouver, BC
I think the last stab would be remove the drive from the casing and connect to the computer directly. At best it would be the control board in the case that's dead or at worst your drive is dying.
Inik
Montreal
I ripped it out of the enclosure and well it's still the same :(
I was able to see it in Disk Management, but it's RAW. Is there a program I should use for data recovery ?
enaberif
Calgahree, AB
What type of drive? WD Green?
RAW means the partition is corrupt.. Free? Try Recuva.
Inik
Montreal
The problem is that firing the program if the drive is connected make it stall. I disconnect it, the program opens but stall when I connect the drive back
enaberif
Calgahree, AB
If the drive stalls its done for. You could try sticking it in the freezer for awhile and then put it on a ice pack to keep it cold and it may work.
But generally when a drive stalls.. its hosed completely.
3.0charlie
Bedford QC
I use a BlacX external enclosure specifically for that purpose. Allows me to start the program first, then power up the drive. Usually works.
And I've saved data on numerous drives with the freezer method (in a sealed zip-loc bag, 24 hours). One to this day still does not want to initialize (tick o' death) on a WD Blue.
