Unstable Internet Connection
A_Dude
Hello guys, im not sure if this is the right forum to post on, but i'll try.
Im having a problem with my internet connection. I have a TP-Link Wireless Modem/Router. On my computer i have a "Basic Belkin USB Adapter", it basicly picks up the Wifi so i can use it.
My problem is that the Internet connection is very Unstable, it isnt 6-8 mbit/s like it should be, its 0-5 mbit, mostly 0-2. And it used be perfectly fine, other computers on the network are more stable, they dont drop to 0, they stay at 3-7 mbit.
But! If i use chorded internet, it stays at 7-8/s.
I have no idea what the problem might be, i tried uninstalling Avast, i tried using other internet browsers and i have tried turning off the firewall, ive also tried Reseting the Modem/Router.
So i dont know what to do, is it the Modems fault? Or the computers?
Thanks in Advance! :)
stoanee
Lacombe Alberta
Judging by the reviews on those usb antennae they can be prone to dropped signals, overheating and sometimes outright failure after a few months. I had an Asus unit and even though it was regarded as one of the better ones it was no powerhouse. My router is in the basement ceiling area and it could barely pick up a signal on the upper floor in a two story. My Dlink pcie card is doing much better in the same spot. If you change the stick over to another computer is it flakey too? Might be time to try a better unit.
A_Dude
Well, the thing is i dont have a built in PCI card that picks up the wifi. The actual Modem/Router is hanging in the ceiling on the bottom floor, and it usually picks up 4-5 bars. In my mobo i have only chorded internet, so i bought a USB thingy from Belkin to pick up the wifi, and yeah, when i resetted the TP-Link modem, i felt that it was kinda hot.
A_Dude
And ive tried with another USB thingy from Asus, and it performed worse actually, only got 2-3 bars.
A_Dude
why not go wired connection ? also what modem/router/wifi using for network?
Mom dosent want to change back haha :( I have a TP-Link Modem and Router in one. Model "300Mbps Wireless N ADSL2+ Modem Router TD-W8961ND"
The modem/router is wireless but it has 4 chord-ports too.
KaptCrunch
Ontario
well i see a firmware update _V1_100617 fixes
Fix the low rate of wireless connection.
Add the compatibility with the XBOX.
Fix the problem that IGMP SOONP not take effect.
to verifi what version got
first read manual pdf then check firmware by sticker or run web intergration
momma whats all the power with you on air
if plugged in router will share the internet bandwidth with her
A_Dude
Thanks, i Will try that, i also spoke with My ISP, they said that there was something sting with the wireing in My area so they Will replace it monday-wednesday
