Update navigation system on a car
Alpine
Age
48
Hello,
Anybody here have already done a update the navigation/ multimedia on their hyundai elantra using Hyundai Navigation Updater ?
Im using a fat32 usb thumb drive as requested. Every files copied.
Put usb stick in the appropriate entry and nothing appen except playing the two wave files download that come using thr navigation Updater on windows
Put usb stick in the appropriate slut
I don't think that's how it works. I never put a USB into a promiscuous person's opening and expect them to update my motherboard's BIOS.
In seriousness, I don't have a Hyundai, all my cars are made in 1999. But looking at the Hyundai's instruction and you are using a 64GB stick, then all you have to do is select the correct car model. It would return a correctly formatted stick with all the files like Rufus. So may be you got the wrong car model or nav model? May be escalate since I did see a Reddit thread dated a few months ago saying it didn't work.
Sorry for wrong word o made the correction
USB is the correct way for my car. I will try another time and in the worst case, i will make a call to the dealer
Do you have anything smaller than 64GB ?
Some systems has trouble with anything more than 32GB, even if formated properly as Fat32.
