Lysrin
Finally got around to getting the Thermalright Phantom Spirit Evo installed and the black Thermalright fans.
Very pleased with the results in terms of cooling. Tested DA:The Veilguard that seemed to be running my CPU the hottest, and I went from a peak temp of 88-89 C in came to a max 79 C, usually 76-78 C, with things staying nice and quiet, and that is with the CPU running between 4700 and 4800 MHz. So I am very please with that. That's at least a 10 C drop in temps over the smaller Noctua NH-U12A I had.
Always has to be something with me and a build, but one of the 120 mm case fans seems to have a very slight tick sound that comes and goes. I'll see if it sorts itself out or if it bugs me enough to have to pursue a replacement. Everything else is so quiet I can definitely notice it when it's happening.
I had an oddity on post where all the fans would spin, but I'd get stuck at the boot light and nothing. Fixed by making sure everything was seated correctly, appeared to be, and then unplugging the 24-pin power and reconnecting it. Then everything came up as normal *shrug*
Few pics of the update that I'm calling My "Noir" Phase
Long way from my fairly shiny custom loop but I really like this look for a change. The Phantom Spirit Evo is darn purty.
The mixed white and black build I started with. Really custom loop leftovers when I switched back to air.
Always good to have a tech helper!
Case fans removed and awaiting the Phantom Spirit Evo:
And the finished result. Slight off colour from my headlamp, but it was too dark with nothing.
The only lighting in the case is just the ROG logo at the top left, set to red when powered on the strobing when powered off.
