This is a continuation of great_big_abyss 's RX5600XT thread, but I didn't want to take over his thread so I'm making a new one....
Essentially I need to update a Z68 board to a "beta" UEFI bios for video card compatibility and I'm a little bit leery of my options.
www.gigabyte.com
That's the link for the board which includes this little nugget as a note for the bios upgrade....
When you unpack the 7zip bios file you end up with flashefi.exe + and autoexec.bat which would load the .U1L bios file (presumably from within windows) as opposed to using the standard Q-Bios method to flash the bios from within the motherboard's configuration utility.
The snag is that this file is not compatible with windows 10 (16 bit only) and won't install from within windows so I'm looking for options....
Has anybody done something similar with success? I could try going the Q-Flash route, but I'm concerned that the UEFI update might not be compatible with the existing bios setup (I have the most recent prior to the beta bios). There's also apparently a 64bit version of the flashefi.exe file out there, but I have no idea if it would be compatible with the motherboard and/or bios file.
The other option is to create a dos boot usb stick and run it from there, but that takes us back to the bad old days of hoping your USB stick doesn't fail during the bios update.
Any suggestions?
GA-Z68XP-UD4 (rev. 1.0) Support | Motherboard - GIGABYTE Canada
Supports for LGA1155 2nd Generation Intel® Core™ Processors Innovative 16 phase power VRM design for optimum power efficiencyTouch BIOS™ delivers No Need fo...
UEFI BIOS
(When updating from legacy to UEFI, use only the utility attached to your BIOS file)
Any suggestions?
