Upgrade Question - rtx 2080 to RTX 2080 Super
deathst
Active member
is it worth to upgrade my asus rtx 2080 oc (Standard) to the RTX 2080 Super?
will the performance be better if i will buy the RTX 2080 Super?
Entz
Kelowna
The difference is around 8% (aka single digit gains at 4k) . I personally don't feel like it would be worth it unless you can get an amazing resale value for your 2080.
JD
Toronto, ON
You'd be better off going up to a 2080 Ti if you really need to upgrade.
deathst
Active member
in 1440p resolutions the performance between 2080 and 2080 super is only 5-8 % or more??
Bond007
Nova Scotia
not worth it, since the gain is not significant enough. What is the rest of of your computer? Is another component holding your GPU back?
deathst
Active member
i have now one 4770k in 4,5 oc.,., and i have the AORUS AD27QD Gaming Monitor
in 1440p the main and most part takes the cpu or the gpu ?? for the games i mean.
i am saying in 1440p will i have botleneck from my 4770k?
JD
Toronto, ON
I'd say your 4770k is already holding back the 2080, it will only be worse if you upgrade the video card further.
I'm not entirely confident in this site, but it says you have a 38% bottleneck currently: https://pc-builds.com/calculator/Core_i7-4770K/GeForce_RTX_2080/0uX12llu/8/
My personal estimate would be more around 20%, but that's still more to gain than you would get from upgrading to a 2080 Super or 2080 Ti.
deathst
Active member
so tell me please something do we have any information if intel and amd will release new cpus the next year? or this year??
Bond007
Nova Scotia
I think next year, but I don’t expect anything amazing. AMD is just better right now.
How much ram do you have? How fast is it?
